05-16-2023 09:09 AM
I have a Cisco sx80 that has a expired certificate on it. When I logon to the administration manager and go to security and look at the current expired certificate the delete button is grayed out for me..
I am looking to regenerate CSR for certificate ... A reboot does not work on this...
Any help would be awesome.
05-17-2023 02:33 AM
I think, you cannot regenerate a self-signed certificate on the endpoint itself.
Either try to factory reset the endpoint, or generate a new certificate and private key and install them on the endpoint.
On the other hand:
If you don't use encrypted communication (e.g. SIP/TLS) then you don't need a valid certificate.
Just the browser will display you a error message, when opening the Web-GUI of the endpoint.
05-17-2023 04:29 AM
Other then Factory reset how would you generate a new certificate if the administration section doesn't give you the option to? The STIG calls for a updated signed certificate.
We do use encrypted comms
05-17-2023 04:40 AM - edited 05-17-2023 04:40 AM
Nobody said, that you need to do it on the endpoint. Ever heard of OpenSSL? Or just let your internal CA generate a Cert / private key.
But anyway, in the other thread, you have all the solutions available from the endpoint's perspective
05-20-2023 08:21 PM
AFAIK a reboot will help you generate the expired certificate.
05-17-2023 02:54 AM
