Getting huge packet loss for multi site call.
Hi Can any one please help me over here, getting huge packet loss for the multi site call, Find the below event logs from the one of the endpoint and let me know how to fix this.
DEVICES ARE INVOLVED HERE ALL ARE CISCO SX20, aLL ARE REGISTERED TO cucm WITH SIP URI.
Endpoint 1 ME1 Details
IP: 172.25.XX.XX
Sip URi: 83650@apcucm.com
software version: TC7.3.7.01c84fd has multisite option
Endpoint 2 HK0 APHQ VICTORIA HARBOUR
IP:
Sip URi: 87717@apcucm.com
Softeware version: TC7.3.7.01c84fd has multisite option
Endpoint 3 SY1 HARBOUR ROOM
IP: 172.16.XX.XX
Sip URi: 82049@apcucm.com
Softeware version: TC7.3.7.01c84fd do not have Multisite option
2017-03-09T11:08:03.161+08:00 a8 appl[1663]: 629820.65 MainEvents I: ActiveSpeakerIndication(c=21,p=28) 2017-03-09T14:08:06.000+08:00 a8 vcodec: DEC_FSM-0: Still experiencing decode errors (32) 2017-03-09T11:08:16.730+08:00 a8 appl[1663]: 629834.22 CuilApp User admin(1001) about to execute command '/Audio/Sound/Stop' from . 2017-03-09T14:08:25.000+08:00 a8 vcodec: WARNING: Encoder overproduction (ttvenc_h264_ivahd): 2017-03-09T14:08:25.000+08:00 a8 vcodec: configured rate 320000, actual rate 486561 2017-03-09T14:08:25.000+08:00 a8 vcodec: 4 frame periods of extra delay would be seen if data paced at configured rate 2017-03-09T14:09:01.000+08:00 a8 vcodec: WARNING: Encoder overproduction (ttvenc_h264_ivahd): 2017-03-09T14:09:01.000+08:00 a8 vcodec: configured rate 320000, actual rate 539536 2017-03-09T14:09:01.000+08:00 a8 vcodec: 5 frame periods of extra delay would be seen if data paced at configured rate 2017-03-09T11:09:55.908+08:00 a8 appl[1663]: 629933.40 MainEvents I: InputAudioChannelChanged(p=29,gid=514) channels=2 encryption=Off muted=False protocol=Off 2017-03-09T11:09:56.396+08:00 a8 appl[1663]: 629933.88 MainEvents I: InputAudioChannelChanged(p=29,gid=514) channels=1 encryption=Off muted=False protocol=AACLD 2017-03-09T11:10:17.979+08:00 a8 appl[1663]: 629955.47 MainEvents I: ActiveSpeakerReported(c=21,p=29) 2017-03-09T11:10:17.981+08:00 a8 appl[1663]: 629955.47 MainEvents I: ActiveSpeakerIndication(c=21,p=29) 2017-03-09T11:11:13.841+08:00 a8 appl[1663]: 630011.33 MainEvents I: ActiveSpeakerReported(c=21,p=28) 2017-03-09T11:11:13.843+08:00 a8 appl[1663]: 630011.33 MainEvents I: ActiveSpeakerIndication(c=21,p=28) 2017-03-09T14:11:35.000+08:00 a8 vcodec: DEC_FSM-0: No decode errors in 209 s, turning output on again 2017-03-09T14:11:35.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x80000000|Prev. frame lost| 2017-03-09T14:11:35.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x80000000|Prev. frame lost| 2017-03-09T14:11:35.000+08:00 a8 vcodec: DEC_FSM-1: No decode errors in 174 s, turning output on again 2017-03-09T14:11:35.000+08:00 a8 vcodec: DEC_FSM-1: Decode Err: 0x02000a00|Concealment Applied|Missing slice| 2017-03-09T14:11:42.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x02000a00|Concealment Applied|Missing slice| 2017-03-09T14:11:42.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x02000a00|Concealment Applied|Missing slice| 2017-03-09T14:11:42.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x02000a00|Concealment Applied|Missing slice| 2017-03-09T14:11:42.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x82000a00|Concealment Applied|Missing slice|Prev. frame lost| 2017-03-09T14:11:42.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x02000a00|Concealment Applied|Missing slice| 2017-03-09T14:11:42.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x02000a00|Concealment Applied|Missing slice| 2017-03-09T14:11:42.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x02000a00|Concealment Applied|Missing slice| 2017-03-09T14:11:42.000+08:00 a8 vcodec: DEC_FSM-0: Decode Err: 0x02000a00|Concealment Applied|Missing slice| 2017-03-09T14:11:42.000+08:00 a8 vcodec: DEC_FSM-0: Continually experiencing decode errors, suppressing further output
Appreciate for your help.
23 Replies 23
Try lowering the bandwidth of the calls. When you are hosting a call on the SX20 you are using more bandwidth than a P2P call. My guess is you simply don't have enough bandwidth to support the calls you are trying to make at the hosting site. For example - if your hosting site has a 1.5M connection to the WAN and your call rate is 768 - one call will work perfectly. Two - you'll get some packet loss (depending on movement in the calls), and three would be horrible. Keep in mind that whatever your call rate is you need to add 20% to allow for IP overhead.
If you drop your call rate and the packet loss goes away bandwidth is undoubtedly your problem. Try 384K.
As Patrick says - try lower the call bandwidth so that the sum total bandwidth of the multisite call is the same as the point to point
The multisite hosting endpoint should have bandwidth capacity for both calls reserved, generally it should be call bandwidth+25%. So for a 2mb call your network should have 2.5mb reserved. It's possible to have it configured with lower than 2.5Mb but I'd start from there. You should then be able to make two 1mb calls or one 2mb call
Ray Boland
Further to what Patrick said, compare the packet loss stats of the multisite call with a point to point call to each site individually as well, and then have the two far sides dial each other.
The recommendation for bandwidth reservation is that you reserve call bandwidth+25% for each video call. For instance, if you want to make 2Mb calls, configure the link so the VC unit gets 2.5Mb bandwidth end to end per call.
Also, packet loss is directional (transmit (TX) and receive (RX). Concentrate on the units that have TX packetloss first. It's also easier to focus on getting two sites working perfectly first, then focus on multisite calls after.
Hi Ray,
Thanks for the reply, We are not observing any packet loss for the point to point call (not changing any bandwidth) 6% packet loss for the multi site call.(am seeing packet loss where the confrerence is hoisted and Tx is 2% and Rx is 6%).
thank you
veera.
Currently i have similiar issue,
I do have SX80 with speakerTrack CE8.3.1, CUCM 11.5, vTS 4.4(1.19), and conductor 4.3.
In my environment,
packet loss only happen when i do multistream call from SX80 in branches offices,
packet loss amount around 10%-30%.
But when i do call non multistream, the packet loss is 0%.
Both multistream and non multistream use 6Mbps and use 3 SX80s as participant for this test call.
Other thing is packet loss in multistream mode has bigger amount packet loss (20%-30%) only in lowest video resolution,
Stream 1080p = Packet loss 8%
Stream 180p = Packet loss 20%-30%
Btw i'm using "Overlay" for video layout
We already talk to WAN admin and also WAN provider and they said this is the best route that they can give for WAN connection. We don't have any QoS and all duplex is in correct configuration.
Anyone experience same issue like this?
Ovindo
Have you resolved your issues, Ovindo?
try disable FEC on SX.
Unfortunately there is no way to disable FEC on sx20 ruining CE firmware.. either xconfig or web there is no option..
