Hardware Network Requirements for CTS 3010 Room
alberto.orden
Beginner
Beginner
Hi everyone,
I would like to know what routers and switches (models) are recommended for the CTS 3010 room, know that need 2 Gigabit Ethernet ( one for the Codec and the other one is recommended for managment ) , then this Switch X is connected to the Router X and that needs minimum 15 mbps to the network infraestructure.
Best regards,
Alberto
Arun Kumar
Hi Alberto,
Please check the datasheet for CTS-3010 (
http://www.cisco.com/en/US/prod/collateral/ps7060/ps8329/ps8330/ps8333/ps10753/data_sheet_c78-579689.pdf) will be some use and you will be able to decide but, if you still like to hear what Router/Switch please let us know.
Arun
Recognize Your Peers
