03-01-2013 08:53 AM - last edited on 03-25-2019 09:07 PM by ciscomoderator
My organization has a couple E20's and are still running CUCM 7.1.5.33900-10. Has anyone successfully registered an E20 in this version of CUCM? If so, need some guidance. Thanks!
03-01-2013 09:01 AM
Hello - The E20 IP Video Phone was first introduced with UCM release 8.5(1). There are some additional enhancements in 8.6 that you can get from the E20 by upgrading your UCM Node / Cluster. You're not going to have a great deal of luck with 7.1.5 though.
Sorry,
-Andrew
03-04-2013 06:03 AM
You may register an E20 to CUCM v 7.x by using the Third-party SIP Device (Advanced) device type. The configuration overview is as follows:
or from the cli
Hope this helps,
Paul
03-04-2013 07:33 AM
Thanks Paul. I gave this to our telecom tech and he was not successful. He feels he is overlooking something simple, so he is still reviewing the setup. One thing we noted on the E20 was the Reason was "404 Not Found". Also we have the Tandberg 2.2 software on the E20 if that matters. Based on your experience, where should he concentrate his efforts, on the CUCM side or E20 side? Thanks again!
03-04-2013 07:48 AM
A 404 not found indicates that the CCM cannot find the device or user in the database. I would verify the following:
If you don't find any inconsistancies there, can you try logging into the console of the e20 via ssh and entering these commands:
log output on
log ctx sippacket debug 9
Then wait a few seconds for a registration message and the two responses from the CUCM and attach them here (you can redact any IP addresses as needed).
Paul
