04-09-2019 09:10 AM
Cisco Telepresence Team
I have a few questions, they are:
KJ
04-09-2019 10:42 AM
Hello Kirk - long time no see!
Cisco supports HDCP on some - but not all systems. See page 31 of the latest release notes:
Per the release notes, version 1.4 only.
Enabling it is indeed via API, I just checked one of my endpoints, it's not in the web GUI.
As for versions, it depends on what specific endpoint, 9.6.1 added support for some that didn't previously have it, so if you just wanted to say "you need this" - go with CE9.6.1 or 9.7
Take a look at the admin guide for the endpoint you are interested in and it will tell you the command you need to run - it varies with the different endpoints because the port(s) that support HDCP will vary.
Hope this helps!
04-25-2019 08:38 PM
As @PJMack said, it's HDCP version 1.4, and you will need to be running a recent software load (at least CE9.6.1) on most of the Room Series endpoints to be able to see HDCP protected content locally (you are not able to transmit HDCP content while in a call).
WIth the more recent software versions (I checked in the latest available at the time of this post being CE9.7.1), the option to enable HDCP on selected inputs is available in the Web interface as well as being able to do it via the CLI.
Please remember to mark helpful responses and to set your question as answered if appropriate.
