HDMI-CEC no longer working with SX20 - TC6.0.1.65?
Darren McKinnon
I have 2 SX20 installations that use Samsung LED Consumer grade TVs that used to be able to use HDMI-CEC function to control the TV during sleep and wake modes for the codec.  Since upgrading to the latest software, this function does not appear to be working.  Is anyone else experiencing this issue?
Darren
Ravi Yadav
Level 4
Level 4
Hi Darren,
upgrading the software will not makes changes on the CEC fuctionality, so what you are saying is before you upgraded there was no issue .
please provide the xconf logs from the SX20.
Please confirm the CEC mode on SX 20 : on/off
Did you tried any other monitor, did you experienced the same issue ?
if yes what was the model of the monitor/TV
Ravi kr
KEVIN STEWART
Did you get this to work again?  Also which Samsung monitors are you using and are you using 2 or just 1?
