10-11-2012 09:26 AM - edited 03-17-2019 11:57 PM
We have VCS-C and VCS-E only, no CUCM and TMS, just want to know if we can make phonebook working at MX200 or 300.
Kevin
Solved! Go to Solution.
10-11-2012 11:47 AM
Hi, you can create up 100 or so entries in the local phonebook. Then you can copy the pb file across to the other endpoints but without the tms you wont get the corporate phonebook. And the local phonebook is a manual pr endpoint work. If you want a more flexible solutiom you should aquire the tms
/Magnus
10-11-2012 11:47 AM
/Magnus
10-11-2012 03:40 PM
Thanks Magnus.
How can I get the pb file from C40?
10-11-2012 05:20 PM
Pb.xml file is located in "config" folder . log in to codec by winscp using root user and copy the file .
You can paste same file using winscp to other EP .
Kind regards,
Dharmmesh
10-11-2012 06:51 PM
Thanks man!!
10-13-2012 05:51 AM
Magnus: Is there a API description to make your own phonebook server?
10-13-2012 09:44 AM
Hi Martin
Not that i know of, but i doubt it. I never heard of it at least.
/Magnus
10-15-2012 02:34 AM
The only TMS API that we publically and externally support is the Booking API. And trying to create your own PB server in replacement to TMS wouldn't be a trivial task either And c'mon guys, one of the main and nicest features of the TMS are the Corporate PBs
