How can I limit webRTC users connection channel rate?
Quzky
Hello Everyone,
I have a question for CMA users BW limitation. How can I do the following scenario?:
"The connection speeds of webRTC participants should be limited to a minimum of 300 kbps and a maximum of 2mbps."
This means that, any participant can not join the meeting If connection channel rate under 300 kbps. Also max channel rate must be 2mbps.
I know there is a configuration on CMS WebAdmin >Configuration>Call settings> Bandwidth settings (CMA), What does it mean, is it cover my scenario?
Thank you
0 Replies 0
