How to delete a Multisite Option Key From EX90
gujiguy2642
Beginner
Beginner
I am trying to delete the multisite option key for a EX90 endpoint.
Does anyone know how can i do it ?
I do not see any option through the webinterface that i could use to delete a option key.
Guji
gujiguy2642
Beginner
Beginner
Found the answer :
As long as you have a multiway URL configure, the system will do multiway and not do multisite using the codec internal MCU.
Alternatively,  if you want to remove the multisite key entirely, one easy way is to  use Winscp, goto the config folder and look for the options file.
Open the options file and you will see the multisite ket (e.g 1M003-1-xxxxxxxx).   Delete this key and save the file.
Hi Guji,
If you configure multiway in that case you will not able to add additional audio call , other option is good as it will allow you to add audio call .
Kind regards,
Dharmmesh
