02-10-2016 03:43 AM - edited 03-18-2019 05:33 AM
Dear All,
how do i integrate polycom HDX 800 with CUCM 10.5 ? kindly provide me with documentation/configuring steps.
Solved! Go to Solution.
02-12-2016 01:15 AM
You may refer to this guide and refer to "Registering a Polycom HDX system with Cisco Unified Communications Manager" and go through from page 11.
regards,
Acevirgil
02-10-2016 08:55 AM
I'm afraid that on CUCM you can only refer to the CUCM admin guide which has an appendix on SIP 3rd party endpoints, but we don't have anything on how to configure the device itself, I'm assuming that like most endpoints it has a GUI on which you configure the different protocols, you should try to configure it to look at CUCM, and use the credentials from the user you bind it to.
02-12-2016 01:15 AM
regards,
Acevirgil
