06-14-2013 12:59 AM - edited 03-18-2019 01:17 AM
Hi Guys
I have a question about the VCSE TURN relay function.
I have 2 SX20s in different home workers that they are behind the NAT, and registered to VCSE which used the public ip and enabled the TURN relay service.
The 2 SX20s can call each other by using SIP Call, and i can find out that they used traversal call in VCSE,but never see the TURN relay status,there is none.
With my understanding , they must use the TURN relay to call each other when they behind the NAT,it's that ture?
Do i miss some configuration about that? How can i to make the TURN relay works?
Thanks .
Solved! Go to Solution.
06-14-2013 04:21 AM
Hi friend,
As far as I understand, TC endpoints are able to make calls behind a firewall because they are traversall clients, they have support to H460 and Assent protocols. These protocolS allow endpoints to make and receive calls even behind a firewall.
If you read SX20's technical especifications, you won't find anything saying it supports TURN feature.
Jabber for Telepresence can be configured to use TURN, but TC endpoints don't.
Paulo Souza
06-14-2013 04:21 AM
Hi friend,
Paulo Souza
06-14-2013 04:39 AM
I was just reading a documentation about the new updates on Cisco Telepresence Portfolio, and it says that TC endpoints will support SIP ACE feature on TC6.2 release. So there is no support for this kind of feature yet.
If you are a partner, this is the doc:
https://communities.cisco.com/docs/DOC-34812
Paulo Souza
06-15-2013 02:25 AM
Thanks Paulo, i will check this
06-14-2013 03:29 PM
You need to provision ICE and TURN by deploying the correct provisioning templates for this to work, however, this type of provisioning is currently only supported by JabberVideo (aka Movi), E20 and EX-series (not sure about the MX series).
VCS-E assists H.323 end-points supporting h.460.18/19 and/or Assent to do the firewall traversal at the far end, as Paulo said.
/jens
Please rate replies and mark question as "answered" if applicable.
06-15-2013 02:26 AM
ok, thanks
06-15-2013 05:34 AM
You are welcome!
Paulo Souza
06-16-2013 05:01 PM
Some remarks here.
Jens:
Ice / Turn is currently only supported (if I look in the xml templates) by Movi/JabberVideo/JaberTablet.
So no EX, MX, SX, E, C support by today.
Paulo:
I do not like to post things which are not there jet, especially as things can still change or
are only possible in specific kind of deployments.
Jason:
So the proper answer to Jasons question: by today its not possible to utilize turn on your SX20
If you want to optimize media flow for these systems on sip its possible to place them on public ip
addresses, then media will flow directly in between them using sip, even if they are registered to a VCS-E.
Or if you have many endpoints/clients with the same internal network, get an VCS-C for this network,
that will keep local traffic locally. Or talk to your Cisco partner what might be possible in the future and wait :-)
06-16-2013 05:54 PM
Comes down to semantics, Martin, when I said:
"by deploying the correct provisioning templates for this to work, however, this type of provisioning is currently only supported by JabberVideo (aka Movi), E20 and EX-series" - I was referring to provisioning in general, not ICE/TURN in particular.
"this type of provisioning" being the optimum words in this sentence.
/jens
06-16-2013 10:28 PM
Paulo:
Hi Martin, I understand what you mean. But I think the point of the topic is this, Jason was not understanding correct how SX20 communicates behind a firewall, he thought was necessary to use TURN. Now Jason knows that TURN is not supported by SX20 and it is not necessary for basic firewall traversal. When I said that ICE will be supported in the future, it was just as reference to prove it is not supported today. I am not suggesting Jason to implement ICE, because his enviroment is working now, there is no reason to suggest ICE. I know about ICE's restrictions very well, but that is not the point here.
Paulo Souza
06-17-2013 01:19 AM
An other short site note, as Jason talked about SIP but answers mentioned
h460/assent. These two are h323 related and do not have anything to do with a SIP call.
Jason thought is right that for a sip call behind firewalls you still need some kind of media relay.
This could be a TURN relay, but like said thats not supported on his endpoints.
But thats exactly why a VCS-E has to be used, as this one decides that it will stick in
the media path by using a traversal call which binds the media for both call
legs to the VCS-E which allows communications through firewalls. :-)
06-17-2013 01:46 AM
Yeah, I missed the SIP part, good pick up Martin.
/jens
06-17-2013 07:06 AM
I missed the SIP part too, really good pick up Martin!
Paulo Souza
