HTTP Feedback was unable to post feedback and has stopped
hs7377
Need help with this
VG ALARM TANDBERG: TANDBERG-VG04: HTTP Feedback was unable to post feedback and has stopped\.
Hariharan Sekar
Wayne DeNardi
Apart from the fact that this device is way past its end of support life, and, if used in a production environment, should really be considered to be replaced with something more modern and supportable, the error is suggesting that the device cannot send its feedback to a management server via HTTP.   You'll need to check that the correct server is specified in the configuration and that it is actually reachable using HTTP (it may be set to use HTTPS only).
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
