HTTPS ISSUE USING IE/CHROME/FIREFOX
Chet Cronin
Level 4
Level 4
Web browsing issue with my WEBEX Room 55's.  I was pushing a template via TMS  to three of my systems that have ce9.8.0.
One of my template settings is "http mode:" and I accidentally set it to off vice https.   So I pushed the template.
Than was unable to browse to the systems.  So I used SSH and using xcommand networkservices http mode: https and appreared to turn it back on ?
Now when I browse to the system I get the following:
BAD GATEWAY
The request could not be served due to a proxy error
Return to the front page
When I click on the link "Return to the front page" nothing happens ???
Chet Cronin
Anurag Srivastava1
It happened to me as well my endpoint was registered with CUCM so i disabled and enabled the web access from CUCM age and rebooted the endpoint it works.
Try rebooting the unit if it does not fix try a factory reset and reconfigure it again and see if it works.
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
navidsyed
As you are managing these endpoints through TMS so I would think VCS is a call control in your case.
It happened to me quite often, try another web browser or clear the cache/history from the browser.
Also try the RemoteAccess Allow field if your endpoints are remotely managed endpoints.
