I am not able to enable the xmpp. Getting below eror
cms>
cms> xmpp enable
FAILURE: Callbridge not activated
SUCCESS: Domain configured
SUCCESS: Key and certificate pair match
FAILURE: XMPP server configuraton not complete
cms>
cms>
cms> xmpp callbridge add cms
XMPP must be enabled before configuration
Anurag Srivastava1
Hello
Can you please send the status of callbridge ?
also check if your licenses are not expired
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
