Installation process of codian MCU 4510 with VFO-4500 Video Firewall Option
piyush.shah
Dear All,
Need your support as this is the first time i am going to intsall the Codian MCU 4510 with VFO Feature Requesting you if anybody can share the Standard process for Installing an MCU 4510 with VFO.
Will appreciate your support on the subject Matters.
Piyush Shah
Tomonori Taniguchi
MCU with VFO deployment is quite simple but need to be careful that only allow to configure default gateway on one of port (either port A or port B).
If any additional routing is require, then you must configure static route under “Routes” configuration.
With VFO, you need configure...,
  • Port A
  • Port B
  • Routes (define default gateway and static route and any additional static route as needed).
  • Services (define what service to be enable on each port)
  • Gatekeeper (under H.323) define port to be used
