Invalid Origin when connecting to SX20 via HTTPS behind NAT/PAT
epicolo
Participant
Participant
we have a SX20 that was running CE8.2.2 without problems. This device is behind a NAT/PAT and for  remote mgmt via web we was able to connect like this
ex.:  https://200.200.200.200:9121/web/signin   ->  10.10.10.10 port 443
A was working, the only issue was when to change from one menu to another, the page redirects and it do not include the port, so we need to wait for the timeout and then include the port mannualy.
The proble is that after to upgarde to CE9.1.4, we cannot login anymore.  The SignIn page is presented and after to enter the credential, there is an error just bellow the credential field with "Invalid origin" and stops.
Is it possible to change the HTTPS listen port at the SX20 CE9 ?
Any ideas?
epicolo
Participant
Participant
If i try  https://200.200.200.200:9121/status.xml (the same port, but to read the XML pages)  the codec will chalenge for the credentials and I can log in and read the pages.
SSH connection to a dfferent port also works fine.
This is quite frustrating...
Recognize Your Peers
