08-02-2012 09:22 PM - edited 03-17-2019 11:33 PM
Hi All,
Need you help in choosing ios image for router 3825 support outbound call from sip trunk. Our team is not able to configure Router 3825 router with current image( c3825-advipservicesk9-mz.150-1.M7) for outbound call.
We need to enable bind command under dial peer. ie bind command to be work under voice service voip sip parameter
Thanks, nihit
08-03-2012 04:16 AM
15.1(4)M4 has the dial-peer bind command.
Please remember to rate helpful responses and identify helpful or correct answers.
08-06-2012 01:21 PM
Hello Nihit,
You could not configure bind commands under a dial peer.
In case you were using sip you would go under voice service voip and then sip.
Then you would do bind media source XXXXX bind control source XXXX.
You may also need to add the allow commands under voice service voip.
Let me know if you have further questions.
