Is it possible to have two codec's connected to one camera
leahdozier
We are receiving lots of zoom invites and not all of our invites come from people with zoom's room connector.  As a result, I would like to register one codec to zoom and the other codec to Webex while using a single speaker track or quad camera.  I am thinking I could have a Touch10 for the Zoom codec and a separate Touch10/Navigator for the Webex codec.  Would this configuration be possible?
I doubt that it would be supported or work. Why don't you use one codec and enable it to connect to Webex and Zoom? AFAIK you can configure a device to both do CRC with Zoom, but not set it to be provisioned by Zoom and then keep it as is for Webex, cloud or on-prem reg.
Response Signature
Depending on the model of the codec you are using, I think you'd probably be better off using the codec as usual with Webex, then using it to provide the audio and video over USB to a PC running Zoom as the second option.  There is a whole Webex Space on configuring the endpoints so they can be used this way PROJECT: USB Mode where all the designs and macros are available.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
