06-19-2014 03:36 AM - edited 03-18-2019 03:05 AM
is it possible to upgrade from VCS 7.x to 8.1? Any addon licenses is required?
Thanks, in advance
Solved! Go to Solution.
06-19-2014 07:08 AM
Yes, you can upgrade from X7 to X8, but you will need to obtain a release key for the new version.
You can get this from www.cisco.com/go/licence if you have a valid service contract in your VCS.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
06-19-2014 07:28 AM
In addition to what Wayne has stated, be sure to read the X8.x release notes, notably the changes in ports from the previous versions of the VCS.
I'm not sure if X8.1 is still available to download due to it containing the Heartbleed bug, bug in either case, you should go to X8.1.1.
06-19-2014 07:08 AM
Wayne
09-12-2016 09:30 PM
Hi Wayne,
May i know the part number of service contract of VCS and TMS to do major upgrade?
Thanks.
09-14-2016 08:07 AM
This would depend on the service level of support you purchase for the VCS. Suggest you reach out to your local reseller you purchase through and have them put together a SmartNET quote for you. Refer to the Cisco Smart Net Total Care Service Data Sheet for more information.
06-19-2014 07:28 AM
06-19-2014 07:45 AM
Here you'll find upgrade guides for VCS:
http://www.cisco.com/c/en/us/support/unified-communications/telepresence-video-communication-server-vcs/products-installation-guides-list.html
I once saw a case where the traversal media port range was not set to default 36000 when upgrading from 7.x to 8.x. There was a bug opened for this:
CSCuo94846 xCommand DefaultValuesSet will not default Traversal media port start
Symptom: VCS x8.1 which was upgraded from VCS 7.x will not able to default back Traversal media port start to 3600 using xCommand DefaultValuesSet. Conditions: Restoring configuration using xcommand. xCommand DefaultValuesSet Level: 3 Workaround: Use factory-reset with x8.1 software.
Tere.
Please rate if helpful.
