04-29-2014 03:44 AM - edited 03-18-2019 02:55 AM
Hi Guys,
I have installed ISDN GW 3241 2.2 (1.92) software last week. I went to download it just now and its been removed from the Cisco download site. Is this correct or am I missing something? If it has been removed, why has it been removed and when is an upgrade available?
I can only see 2.1 (1.56) available to download.
Rob
04-29-2014 05:03 PM
It has likely been removed (similar to some of the other products) as it's affected by the Heartbleed OpenSSL vulnerability see http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20140409-heartbleed.
As there is not a newer version of software with Heartbleed fixed it is recommended that you install 2.1.
If you really need one of the other versions, I suggest you contact the TAC who should be able to provide you with another copy of the version you require.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
09-08-2014 06:09 PM
To follow up on this, if you haven't found it already, as listed in CSCuo21486, the Heartbleed fix is available in software version 2.2(1.94)P.
Wayne
