IX5000 screen replacment
bill.sheldon
Is there a document detailling the steps required to replace a screen on an IX5000.
regards
Bill
Patrick Sparkman
You're more than likely going to have to dismantle the unit, follow the IX5000 Install Guide, but going backwards until you're to a point where you can remove the screen that needs to be replaced.  If this is related to an RMA where you received a replacement screen, you should be able to ask TAC on their thoughts regarding how to make the swap.
John Lang
Grab a copy of the Install guide and work backwards. Be cautious with the lighting cover, it can be easily damaged when moved. Also be aware it is very easy to damage the wiring for the lights as you remove and reinstall them. The wires can snag or be cut on the frame.
