03-19-2018 09:23 PM - edited 03-18-2019 01:58 PM
We have a customer with public domain say example.com. We have two CUCM & IMP Cluster in Our Premises. Now we are using Jabber for Entity-1 in domain example.com from Internal and No MRA From External.
Entity-1
Internal Jabber :- Yes
External Jabber :- No
Jabber Domain :- example.com
SRV :- _cisco-uds._tcp.example.com ====> CUCM01.example.local
Now we want to enable Jabber MRA for Entity-2 But we cannot use same Domain as it is already used
External Jabber :- Yes
Jabber Domain :- ?
External Jabber :- ?
Question here is can we configure the SRV Records as s1.example.com so that Entity-1 users will use UserId@example.com and Entity-2 Users will use UserId@S1.example.com as JID.
The Question here is Can we add the SRV Records in External domain
For Entity-1
_collab-edge._tls.example.com
For Entity-2
_collab-edge._tls.s1.example.com
It is supported? Any One Tried similart setup ?
03-19-2018 11:06 PM
03-20-2018 08:59 AM
You CAN use the same domain, just configure ILS to find the home cluster of users for on-prem and/or MRA
Using a sub-domain is also an option, just configure all the required SRVs in the appropriate domain.
01-15-2022 12:56 AM - edited 01-15-2022 01:06 AM
Good morning sir. I know this thread is old but i want to achieve similar thing.
I want to make use of the subdomain option. There is no separate dns records for both subdomain and main domain.So i want to create host record for the subdomains as follows
Site 1
Host A: h1.sipzon.com
srv record
service: _collab-edge
protocol: _tls
priority: 5
weight: 10
target: h1.sipzon.com
if user of site 1 wants to login,the jabber id will be : user1@h1.sipzon.com
srv record will fail because _collab-edge._tls.h1.sipzon.com does not exist.
what exists is _collab-edge._tls.sipzon.com
Site 2
Host A: h2.sipzon.com
srv record
protocol: _tls
priority: 10
weight: 15
target: h2.sipzon.com
if user of site 2 wants to login,the jabber id will be : user2@h2.sipzon.com
srv record will fail because _collab-edge._tls.h2.sipzon.com does not exist.
what is the best way to achieve it using subdomain option?
01-15-2022 01:17 AM
If the domain is h1.sipzon.com you’ll need to have a collab edge SRV record in this domain for it to work or you’ll need to set the voice domain configuration record in the Jabber configuration or if you use Webex with CM phone services you’ll need to define a service domain in Control Hub that is set to sipzon.com.
01-15-2022 01:30 AM - edited 01-15-2022 01:34 AM
Hello Roger,
thanks for the response.can h1.sipzon.com be created as a subdomain the public dns registrar.I contacted some domain providers like bluehost but they say they don't have separate dns records for both subdomain and main domain.
so i want to use A record in place of subdomain .
yes i will set up sipzon.com as the voice service domain.will this prevent the srv look up from failing?
01-15-2022 07:15 AM
I’m not DNS expert, so I will refrain from commenting on this part.
Yes if you define the voice service domain as discussed it should result in a working service discovery.
01-17-2022 08:01 AM
Thank you Roger for your kind response.
01-15-2022 04:28 AM
Hello Roger,
In case I decide to use ILS, will i add all the clusters to the expressway E? can you sketch a diagram on how integrate ILS with expressway e
01-15-2022 07:11 AM - edited 01-15-2022 07:18 AM
The Expressway E does not know anything about ILS. It’s the Expressway C in a MRA setup that knows about the CM’s and uses UDS to query a CM, any can respond, about the users home cluster. This information is distributed across CM cluster that are part of the ILS network.
