Jabber for iPad - TMS provisioning template
Patrick Sparkman
First off, I wasn't sure where to post this.. either in the Jabber for iPad or TelePresence section.  So I figured since it involves TMS, I'd put it here.
Where can we download the TMS provisioning template for the new Jabber for iPad release when trying to configure it for video?  It provides a link to where you can download the template, but there is no section for iPad.  The documentation pertaining to setting it up with TMS and VCS is linked below, it's just as if we were configuring Jabber Video for TelePresence (Windows/MAC).
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/iPad/Admin_doc/output/b_Jabber_for_iPad_admin_guide_chapter_011.html#concept_2A3A1909CB6E43F19BECF9F04F765B75
Thanks, Patrick
Hi Tom et All,
Attached is the TMS Provisioning template. It should be posted on CCO within a few days.
Paul
Edit: The provisioning template has been posted to CCO here:
http://download.cisco.com/swc/esd/06/284288351/contract/jabbertablet_provisioning_template.xml
Release notes are here:
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/iPad/Release_notes/output/b_release_notes.html
Attachement removed.
13 Replies 13
Oscar Garza
Frequent Visitor
Frequent Visitor
Good question. I am reading the same document and looking for the same answer.
gg_robinson
Good to see I'm not the only one.
Thought I was going crazy for a while.
Yes, would love to be able to find the template as well. I already had users emailing me last night asking how soon they can start using it.
Thanks.
Hi Tom et All,
Paul
Hello Paul, thank you for the template, very much appreciated!
Yes, thank you very much.
Jabber for iPad, 6 months so I guess we will have to wait another 6 months for the template
UPDATE!!!!! Template has been updated to the post....
THANK YOU!
Billy - please check a few posts above, the template has been provided in the discussion thanks to Paul.
In addition, here is the direct link to the support docs and download area for Jabber for the iPad.
- Paula
I have the template and it works but presence is not working. We are running TMS 13.1.2 and we have our users provisoned via TMS. The documentation says to update the template with the phonebook and presence server names (URI's) not sure where to put these in. Can someone help? thanks It also talks about putting in the SIP server address but it seems to be able to connect into the confeernces without this field being changed. I basically just uploaded the template into the provisioning directory from TMS
I have the same issue so any suggestions would be very mutch appreciated
Per
You need to create a new template based on the schema you uploaded.
Go to Configuration Templates, expand JabberTablet, click on 1.0 which sits below JabberTablet, no go to the top and click "Add template" (right below "Comfugration Templates"), call it what you want, save and you can now open this and edit configuration settings to suit your deployment.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Here is a discussion on the same issue wayne and Per, however there isn't any replies yet.
https://supportforums.cisco.com/thread/2160589
