03-06-2015 01:04 PM - edited 03-18-2019 04:09 AM
Jabber Guest Configuration :
HI,
I am Going to deploy Jabber guest Server in our Production
network
can u guys please tell me we need to advertised any srv record for jabber
guest deployement
03-06-2015 02:35 PM
See the Ports and Protocols section of the Jabber Guest Install Guide starting on pg 30. Because Jabber Guest calling is always outside in, it uses a reverse proxy to access your video network via your VCS Expressway or Expressway Edge server.
03-07-2015 09:45 AM
Hi Patrick,
Thanks For your reply
Please tell me we need to advertised any SRV or A records in external dns
03-07-2015 10:02 AM
Users will navigate to a webpage where you have the Jabber Guest plugin in place, or they'd click a provided link and it would send them to the VCS-E or Expressway-E to and using reverse proxy, communicate to the Jabber Guest server.
You'll need A records with associated FQDN pointing to your VCS-E or Expressway-E for Jabber Guest to use. No SRV records are not needed.
Highly suggest you look over the install guide I linked to above, it has everything you need to set up Jabber Guest.
03-07-2015 11:34 AM
Thanks Patrick
03-20-2015 02:42 AM
03-20-2015 07:39 AM
Did you setup your firewall to remap the incoming Jabber Video web requests on 80/433 to 9980/9443?
03-20-2015 07:48 AM
Hi For testing i opend all the ports
i have doubts can you please clarify ??
we need to setup neighbor zone between
expressway-c --------- jabber guest
expressway e --------- jabber guest
expresswayc----- cucm
expresswaye---- expressway c = traversal communication zone .
03-20-2015 08:06 AM
Refer to the network topology on pg 25 of the deployment guide I linked to earlier for how the Jabber Guest server is supposed to be installed within your network depending on how your environment is setup.
It's only recommended to deploy Jabber Guest directly to CUCM in a lab environment to familiarize yourself with Jabber Guest. Any other time, Jabber Guest should be deployed with Expressway.
