04-24-2012 04:16 PM - edited 03-17-2019 11:06 PM
We have issues with video calls between Cisco C20 and Sony PCS-1 endpoints
When a PC/Laptop presentation is started from the C20 during a Video call, the receiving side (Sony PCS-1 endpoint) gets a fixed- image. The audio part of the video remains ok.
This doesn’t happen when the presentation is started from the Sony endpoint.
The problem also doesn’t occur if the video call is between 2 C20 or between 2 Sony PCS-1 endpoints.
All devices are registered on the VCS (version 7.1). There is an MCU 4500 for multiway.
C20 Software Version: TC 5.1
Sony PCS-1 Software version: 3.42
Has anybody experienced this problem before?
05-03-2012 12:00 PM
Hy out there
we hava a similar Problem with Sony C20, EX60, EX90, c40 when communication to sony endpoints.
After a while the Video Freeze and only audio goes threw.
This only happens if the Cisco Endpoint is Release 4.2 and later
cheers
05-03-2012 12:19 PM
Hi All,
Sony PCS-1 is not fully interoperable with C series. Here is the section pointing that out :
Here's the note for your reference :
Dual stream is limited to 1 FPS. The main video frame rate will never exceed 15 FPS.
Hope this answers your question.
Please rate the answers using the stars below this post.
Mubashshir Akhtar
05-03-2012 12:20 PM
For more information, you can refer to the release notes of TC5:
05-04-2012 04:00 AM
Hi Emmanuel,
Cisco/Tandberg Endpoints are not fully interoperable with all Vendors and thier are certain limitations to some extent. The case which you are talking here is one of them but before going ahead with any conclusion.
You need to narrow things down by performing troubleshooting .
Here are some steps which you can check :-
1.) You can bypass all infrastructure devices in between and then try Presentation Sharing again.
2. ) As clearly Stated in Mubashshir's post, this issue is in TC 5, then please downgrade your endpoint to TC 4 and check again.
3. ) Try to collect logs from both the endpoints which are working and which are not working and then try to compare and check where the problem starts.
4. ) If you see that Tandberg Endpoint is not able to send presentation , then open a bug with Cisco otherwise Open up a Bug with Sony.
Saurabh
08-20-2013 07:42 AM
Does this Bug with TC6 still exists?
Martin
08-20-2013 12:07 PM
Martin -
It's still present according to the TC6.x release notes (page 73).
