Largest file size of one recording of TCS
Hi all,
We plan to quote a TCS on our customer's environment, but we don't have information below.
Does anybody know...
1.the largest file size of one recording of TCS?
2.the largest file size of multiple recordings of TCS in total?
3.the longest recording time on TCS?
(we use 1Mbps for bandwidth for each recording)
Best Regards,
Kotaro Hashimoto
Patrick Sparkman
I don't know the official answers, but I would imagine the answer to all your questions would be based on the storage size of where the media will be held.
ie: local TCS HDD, or external NAS/SAN
One would have to calculate the size of the recording based on it's lenght and bit rate.  Remember you'd have to take into account that for every 1 recording, you'll have at minimum 2 files that would require storage at your specifid location.  1 raw file that is used to output all the various file types from, plus whatever output types you choose (at least one).
mahkrish
Level 3
Level 3
Hi kotaro, Here are few samples.
