License Expressway Rich Media Session, what is?
Hi everybody.
I have a doubt about my rich media sessions on my Exp-E, it says 8 rich media sessions, that's my calls number Expe it is going to permit me to call?
I will use jabber for almost 30 users trough MRA and I don't know if I have to buy a license or sthg like that to permit all my users to make calls
Thanks so much!
Jaime Valencia
No, MRA does not require licenses.
Any of the following would NOT need RMS
internal device to MRA device
MRA device to internal device
MRA device to MRA device
MRA device to PSTN (using the same GW/CUBE your internal devices use)
If you use expressways for B2B calls, then you WOULD consume RMS for incoming/outgoing B2B calls.
java
if this helps, please rate
Jaime Valencia
java
Thanks so much!
It is great!
