Login expired: Invalid cookie issue
Arfan Arshad
cant login into vcs.
Login expired: Invalid cookie error
8 Replies 8
Tao Ren
I have the same issue, the primary vcsc prompts this error when I try to log in, the secondary vcsc does not have this problem. However I need to login the primary vcsc to make a configuration change.
Any help?
One day I had this error after a fresh installation. I had to use the cli command to reset the default password. So try the same maybe.
I can not even ssh with admin login, can only ssh with root which seems not be able to use CLI command.
Just had the same issue, unable to login with any user in the GUI and only the root user via CLI.
When attempting to login to the GUI it would present an error "Login expired: Invalid cookie".
Solution was to login as root and check the filesystem usage with "df-h"
~ # df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda5       939M  566M  325M  64% /
devtmpfs        2.0G     0  2.0G   0% /dev
none            2.0G  244K  2.0G   1% /run
/dev/ram0       190M   50M  130M  28% /var
/dev/loop20     1.5G  1.4G     0 100% /tmp
/dev/sda7       939M  178M  712M  20% /tandberg
/dev/sdb2       220G   13G  197G   6% /mnt/harddisk
Based on the output it became apparent that the /tmp directory was 100% full.
Using the command "ls -lS /tmp" which displays the files in the directory sorted by size, it was easy to tell which file was taking up all of the space.
In my case it was the file "loggingsnapshot.txt" which is stored when you take a diagnostic log. This file had grown to over 1GB in size.
I removed the file with the command "rm /tmp/loggingsnapshot.txt" and then was immediately able to login again.
Hopefully this can help someone else in the future.
Thanks Jonathan,
That is exactly the root cause.
Glad it worked out for you!
Thanks for the info, I had the same issue solved as you have indicated.
Jose Zapata
Chet Cronin
Level 4
Level 4
Problem fixed with server restart ..
Thank you.
Chet Cronin
