Maximum Cable Distance for Quad Cam Connecting to Room Kit Pro
PHSmith
What is the maximum acceptable cable distance for the HDMI and RJ45 cables connecting a quad-cam to a Room Kit Pro?
Wayne DeNardi
Using non-amplified cables, the HDMI can be about 3m.  With amplified cables, it can be further, and with HDMI extenders, then it can be a long way.
The "RJ45" connector needs a standard Ethernet connection, so is subject to the standard Ethernet rules - ie should be no longer than 100m.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
