Mcu 4505 call preconfigured participants
Bar1s
Beginner
Beginner
I created a permanent conference at MCU and added to preconfigured participant which is couple defined endoints.
I setup Invite pre-configured participants field as "When at least one other participant is present".
When I call this conference number Mcu calling other preconfigured participant. All is ok.
But Mcu calling other enpoints with Mcu registration caller id.
Can I setup caller Id as conference name or number when Mcu calling preconfigured participant.
Baris.
Garvan Long
Beginner
Beginner
If you enable" Use conference name as caller ID" check box on the confernece settings page it will use the confernce name as the caller ID
Garvan
Hello Garvan,
Thank you for relpy.
I tried before this option but It is not worked. I coudn't see any difference. Is there need more anthing about that ?
Baris.
Hello Garvan,
I want to add something here. My colleague using MSE 8510 chassis MCU.
It is working with his system. But I am using MCU 4505 with latest software but It doesn't work with us.
Is there any MCU 4505 user here ?
Baris.
