MCU 5320 constantly reboot
v.rubtsov
HI.
In MCU 5320 amended media portal on SD.
MCU has been reset. After these steps are not MCU is loaded.
Constantly rebooting.
40  Copyright 2011, Cisco Systems, Inc. ***
hello from l2!
AMD ucode patch ID: 0000000000000000
exception_init
L2.Pico (LANGLEY) #V_P_2_15j: Wed Jul 18 11:29:07 BST 2012
        TANDBERG@BUILDMACHINE:LANGLEY
Checking system timer ... OK
EEPROM digest:
3c 00 9f 58 ce de de 21 e9 47 a4 2a d8 d8 52 a5
FreeUsbd v.0.1.2
USB code initialised
FIDDLESTICKS
init
Running app_hub app_l2
app
lib
lib_oob
lib_hpi
lib_com
lib_ddr
lib_xaui
lib_vcpu
lib_sbic
lib_emac
lib_edvt
Thu Sep 26,  13:33:04 2013
Last reboot: 0a (power failure)
GX image usbfs1a:gx.img not found
GX image : fat0:gx.img
GX version : AGX_FPGA_2_12_5
PCIx reset done.
Press CTRL+C to interrupt L2 boot
kernel_boot(usbfs1a:kupgrade)
kernel_boot(usbfs2a:kupgrade)
kernel_boot(usbfs1a:kernel)
kernel_boot(usbfs2a:kernel)
kernel_boot(fat0:kupgrade)
kernel_boot(dd0:kernel)
kernel_boot(fat0:kernel)
No fat payload
Image version: V_F_5_15_25:/kernel
entrypoint 0xc0461eb0
KDB: debugger backends: ddb
KDB: current backend: ddb
Copyright (c) 1992-2011 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.2-RELEASE #V_F_5_15_25: Thu Aug  9 18:26:38 BST 2012
    TANDBERG@BUILDMACHINE:LANGLEY i386
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: AMD Unknown (1600.07-MHz 686-class CPU)
  Origin = "AuthenticAMD"  Id = 0x60fb2  Family = f  Model = 6b  Stepping = 2
  Features=0x78bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CM
OV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2>
  Features2=0x2001<SSE3,CX16>
  AMD Features=0xea500800<SYSCALL,NX,MMX+,FFXSR,RDTSCP,LM,3DNow!+,3DNow!>
  AMD Features2=0x11d<LAHF,SVM,ExtAPIC,CR8,Prefetch>
  TSC: P-state invariant
real memory  = 944766976 (901 MB)
avail memory = 897093632 (855 MB)
MPTable: <CODIAN   VOGON       >
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 2 package(s) x 1 core(s)
cpu0 (BSP): APIC ID:  0
cpu1 (AP): APIC ID:  1
ioapic0: Changing APIC ID to 2
ioapic0: Assuming intbase of 0
ioapic1: Changing APIC ID to 3
ioapic1: Assuming intbase of 16
ioapic2: Changing APIC ID to 4
ioapic2: Assuming intbase of 32
ioapic0 <Version 1.1> irqs 0-15 on motherboard
ioapic1 <Version 1.1> irqs 16-31 on motherboard
ioapic2 <Version 1.1> irqs 32-47 on motherboard
prof_info loaded
pcib0: <MPTable Host-PCI bridge> pcibus 0 on motherboard
pci0: <PCI bus> on pcib0
pcib1: <MPTable PCI-PCI bridge> at device 0.0 on pci0
pci1: <PCI bus> on pcib1
pcib2: <MPTable PCI-PCI bridge> at device 13.0 on pci1
pci2: <PCI bus> on pcib2
vfx0: <Vogon FPGA> mem 0xfc200000-0xfc2fffff at device 4.0 on pci2
SERIAL NUMBER: SUK1714000G
vfx0: HIF revision: 2
vfx0: RX ring: count=1024 virtual=0xc4acb000 physical=0x374a4000
vfx0: TX ring: count=512 virtual=0xe43b4000 physical=0x01de6000
vfx0: [GIANT-LOCKED]
vfx0: [FILTER+ITHREAD]
eeprom0: <Vogon/Arthur EEPROM> on vfx0
oob0: <OOB network PCI interface> on vfx0
oob0: TX FIFO is 1024 words, RX FIFO is 1024 words
vfx_if0: <FPGA Ethernet MAC> on vfx0
vfx_if0: Altera MAC core revision a01
miibus0: <MII bus> on vfx_if0
brgphy0: <BCM5482 10/100/1000baseTX PHY> PHY 1 on miibus0
brgphy0:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-m
aster, 1000baseT-FDX, 1000baseT-FDX-master, auto
vfx0: Ethernet address: 00:0d:7c:44:0f:3e
vfx_if1: <FPGA Ethernet MAC> on vfx0
vfx_if1: Altera MAC core revision a01
miibus1: <MII bus> on vfx_if1
brgphy1: <BCM5482 10/100/1000baseTX PHY> PHY 2 on miibus1
brgphy1:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-m
vfx1: Ethernet address: 00:0d:7c:44:0f:3f
fan0: <Fan speed controller> on vfx0
vfx_init_tx_ring 0xc0899a40 - ef 00000800 00000800 media_rx_ring
vfx0: attach done: devmode=00000000
atapci0: <ServerWorks HT1000 SATA150 controller> mem 0xfc100000-0xfc101fff irq 1
1 at device 14.0 on pci1
atapci0: [ITHREAD]
ata2: <ATA channel 0> on atapci0
ata2: [ITHREAD]
ata3: <ATA channel 1> on atapci0
ata3: [ITHREAD]
ata4: <ATA channel 2> on atapci0
ata4: [ITHREAD]
ata5: <ATA channel 3> on atapci0
ata5: [ITHREAD]
atapci1: <ServerWorks HT1000 SATA150 controller> irq 11 at device 14.1 on pci1
atapci1: [ITHREAD]
device_attach: atapci1 attach returned 6
atapci2: <ServerWorks HT1000 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x
177,0x376 at device 1.1 on pci0
ata0: <ATA channel 0> on atapci2
ata0: [ITHREAD]
ata1: <ATA channel 1> on atapci2
ata1: [ITHREAD]
isab0: <PCI-ISA bridge> at device 1.2 on pci0
isa0: <ISA bus> on isab0
pci0: <base peripheral> at device 1.3 (no driver attached)
ohci0: <OHCI (generic) USB controller> port 0x1000-0x10ff mem 0xfc001000-0xfc001
fff irq 10 at device 2.0 on pci0
ohci0: [ITHREAD]
usbus0: <OHCI (generic) USB controller> on ohci0
ohci1: <OHCI (generic) USB controller> port 0x1400-0x14ff mem 0xfc002000-0xfc002
fff irq 10 at device 2.1 on pci0
ohci1: [ITHREAD]
usbus1: <OHCI (generic) USB controller> on ohci1
ehci0: <EHCI (generic) USB 2.0 controller> port 0x1800-0x18ff mem 0xfc003000-0xf
c003fff irq 10 at device 2.2 on pci0
ehci0: [ITHREAD]
usbus2: EHCI version 1.0
usbus2: <EHCI (generic) USB 2.0 controller> on ehci0
cpu0 on motherboard
powernow0: <PowerNow! K8> on cpu0
bios_sigsearch 243
device_attach: powernow0 attach returned 6
cpu1 on motherboard
powernow1: <PowerNow! K8> on cpu1
bios_sigsearch 243
device_attach: powernow1 attach returned 6
uart0: <Non-standard ns8250 class UART with FIFOs> at port 0x3f8-0x3ff irq 4 fla
gs 0x7030 on isa0
uart0: console (38400,n,8,1)
rtc_arthur0: <M41ST85 real-time clock via OOB> on isa0
Timecounters tick every 1.000 msec
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 480Mbps High Speed USB v2.0
ad0: 1907MB <2GB NANDrive D A204GA> at ata0-master PIO4
oob0: starting endpoint discovery
ugen0.1: <(0x1166)> at usbus0
uhub0: <(0x1166) OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <(0x1166)> at usbus1
uhub1: <(0x1166) OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <(0x1166)> at usbus2
uhub2: <(0x1166) EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
oob_generic0: <OOB packet tester> at (08)
oob_regfile0: <OOB register file> at (10)
oob_regfile1: <OOB register file> at (04)
oob_generic1: <OOB packet tester> at (02-80)
oob_inp0: <Ingress network processor> at (20)
oob_inp0: API revision 3; 128 filters
oob_generic2: <Tilera HPI bus> at (02-02-08)
oob_generic3: <Tilera HPI bus> at (02-04-08)
oob_lcd0: <ST7529 LCD controller> at (02-08)
oob_lcd0: dimensions 240x96
oob_generic4: <SPI bus> at (02-10)
oob_generic5: <I2C bus via hub SCU> at (02-40)
oob_regfile2: <OOB register file> at (02-02-20)
oob_regfile3: <OOB register file> at (02-04-20)
oob_generic6: <SPI bus> at (02-02-04)
oob_generic7: <SPI bus> at (02-04-04)
oob_generic8: <I2C bus via compute card SCU> at (02-02-02)
oob_generic9: <I2C bus via compute card SCU> at (02-04-02)
SMP: AP CPU #1 Launched!
Root mount waiting for: usbus2
uhub2: 4 ports with 4 removable, self powered
Trying to mount root from ufs:ad0s2a
Mounting local file systems:.
Entropy harvesting: interrupts ethernet point_to_point kickstart.
Starting Network: lo0.
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
        options=3<RXCSUM,TXCSUM>
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
        inet6 ::1 prefixlen 128
        inet 127.0.0.1 netmask 0xff000000
Starting devd.
Clearing /tmp (X related).
Setting hostuuid: 3d639e82-26b0-11e3-abd1-000d7c440f3e.
Setting hostid: 0x65009725.
Loading stripe module
GEOM_STRIPE: Device extcflash created (id=1987084655).
GEOM_STRIPE: Disk ad0s4b attached to extcflash.
GEOM_STRIPE: Device rdwr created (id=4270661920).
GEOM_STRIPE: Disk ad0s4a attached to rdwr.
GEOM_STRIPE: Disk ad0s3b attached to extcflash.
GEOM_STRIPE: Device extcflash activated.
GEOM_STRIPE: Disk ad0s3a attached to rdwr.
GEOM_STRIPE: Device rdwr activated.
Starting file system checks:
/dev/ad0s2a: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/ad0s2a: clean, 161367 free (23 frags, 20168 blocks, 0.0% fragmentation)
/dev/ad0s2b: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/ad0s2b: clean, 7572 free (20 frags, 944 blocks, 0.3% fragmentation)
/dev/stripe/extcflash: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/stripe/extcflash: clean, 121503 free (23 frags, 15185 blocks, 0.0% fragment
ation)
/dev/stripe/rdwr: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/stripe/rdwr: clean, 16227 free (19 frags, 2026 blocks, 0.1% fragmentation)
Mounting late file systems:.
Hit Ctrl+C in the next 5 seconds to prevent mcu start
RUNNING MCU
net.inet.icmp.drop_redirect: 0 -> 1
** /dev/ad0s1
** Phase 1 - Read and Compare FATs
** Phase 2 - Check Cluster Chains
** Phase 3 - Checking Directories
** Phase 4 - Checking for Lost Files
44 files, 186136 free (23267 clusters)
hw.inp.enable: 0 -> 1
stack at 0xbfbfdcfc
133342.616 SYSTEM : Info : Cisco TelePresence MCU 5320 4.4(3.42) (Build 6.18(3.4
2)) starting
133342.685 SYSTEM : Info : device configuration successfully loaded
ssl init
net.inet.tcp.keepidle: 7200000 -> 60000
net.inet.tcp.keepintvl: 75000 -> 10000
133343.831 SYSTEM : Info : Disabling core dumps
133343.831 UPGRADE : Info : clearing local features cache
133343.832 CLUSTER : Info : feature enabled
133343.872 PIPELOG : Info : network control initialised
133343.878 NETWORK : Info : Initialising IP routes
133343.882 NETWORK : Info : Failed to read network services configuration; assum
ing default settings
133343.932 NETWORK : Info : activating ethernet Port A with auto-negotiation
133343.936 NETWORK : Info : Failed to read network services configuration; assum
133343.945 NETWORK : Info : activating ethernet Port A with auto-negotiation
133343.949 NETWORK : Info : Failed to read network services configuration; assum
133343.958 NETWORK : Info : deactivating port A IPv6
133343.959 NETWORK : Info : activating ethernet Port B with auto-negotiation
133343.972 NETWORK : Info : activating ethernet Port B with auto-negotiation
133343.983 NETWORK : Info : deactivating port B IPv6
133343.983 NETWORK : Info : activating ethernet Port A with auto-negotiation
133343.995 NETWORK : Info : activating port A IPv4 with DHCP
133344.033 NETWORK : Info : activating ethernet Port B with auto-negotiation
133344.045 NETCONF : Info : Starting DHCP on port A IPv4, managed
133344.046 NETWORK : Info : deactivating port B IPv4
133344.099 NETWORK : Info : deactivating port A IPv6
133359.075 UPGRADE : Info : Hardware compatibility: 00000022 / ffffffff
have video forward socket, port 50935
133359.160 USER_MANAGER : Info : 2 users present
133359.183 CUSTOMIZATION : Info : customisation configuration read; starting wit
h 1-off 2-off
133359.183 CUSTOMIZATION : Info : Doing customisation resources init
133359.314 SYSTEM : Info : default text tokens loaded - 6889 tokens (UTF-8 forma
t)
133359.324 RECORD_STORAGE : Info : record_storage module initialised
133359.325 CDR : Info : CDR storage available
133359.325 CDR : Info : Finding archived sections
133359.362 CDR : Info : Finding current sections
133359.754 RECORD_STORAGE : Info : Creating 2 files for CDR module
133359.923 CDR : Info : Creating new current sections
133400.373 CDR : Info : Current sections OK
133400.374 AUDIT : Info : Audit storage available
133400.375 SYSTEM : Info : Unique id initialised
133400.375 SYSTEM : Info : Unique id change thread starting
shell initshell init133400.375 SHELL : Info : Serial shell unsecured
133400.413 CAPABILITIES : Info : Creating 230 capability sets
MCU:> 133400.860 SIP : Info : SIP initialised
133401.068 AUTO_ATTENDANT : Info : initialised - 1 present
133401.082 API : Info : initialised database
133401.190 CONFERENCE : Info : initialising font support
133402.547 RECORD_STORAGE : Info : Creating 2 files for AUDIT module
133404.390 AUDIT : Info : Reading hashes of audit log
133404.390 AUDIT : Info : Calculating file hashes and checking against read hash
133404.390 AUDIT : Info : Completed Audit hash check
vfx_init_tx_ring 0xe43cd000 - 00 00000800 00000800 udph mmap ring
Looking for powered compute cards
==> Compute card 0 SCU at /dev/oob/02/02/02.com [00 01]
==> Compute card 1 SCU at /dev/oob/02/04/02.com [02 03]
compute 0 stat: 01
compute 1 stat: 01
tlr 0: probe okay
tlr 1: probe okay
tlr 2: probe okay
tlr 3: probe okay
multicast_boot: sending tlr_l05.bin
multicast_tlr_image: sent 1884 bytes
multicast_boot: sending tlr_l1.bin
multicast_tlr_image: sent 31352 bytes
multicast_boot: sending tlr_hv.bin
multicast_tlr_image: sent 845236 bytes
multicast_boot: sending tlr_hvfs.bin
multicast_tlr_image: sent 3871080 bytes
tlr 0: booted successfully
tlr 1: booted successfully
tlr 2: booted successfully
tlr 3: booted successfully
tlr 0: probe okay
tlr 1: probe okay
tlr 2: probe okay
tlr 3: probe okay
133429.074 SYSLOG : Info : sending IPv4 from default port
133429.074 SYSLOG : Info : sending IPv6 from default port
133444.574 HEALTH_MONITOR : Info : starting fan speed test
133454.674 HEALTH_MONITOR : Info : fan speed test successful
*** DSP 0 is dead: rebooting ***
XAUI_C0N: DOWN rx_freqlocked=9 rx_syncstatus=00
XAUI_C1N: DOWN rx_freqlocked=d rx_syncstatus=00
STACKING: DOWN rx_freqlocked=b rx_syncstatus=01
133457.750 SYSTEM : Info : shutdown monitor - shutdown initiated
133457.751 GATEKEEPER : Info : shutdown initiated
133457.751 GATEKEEPER : Info : shutdown complete
133458.254 SYSTEM : Info : shutdown process - all priority 100 handlers complete
133458.255 SYSTEM : Info : shutdown process - shutdown complete
Waiting (max 60 seconds) for system process `vnlru' to stop...done
Waiting (max 60 seconds) for system process `fastpath' to stop...done
Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
Waiting (max 60 seconds) for system process `syncer' to stop...
Syncing disks, vnodes remaining...0 done
All buffers synced.
Uptime: 1m40s
Rebooting...
cpu_reset: Stopping other CPUs
Patrick Pettit
Hi.  Definetly looks like a problem with DSP 0.  I'd suggest you raise a case with TAC so we can check with our systems team to see whats up here.
1) Provide about five minutes of console log output of the system rebooting if you can.
2) System version information.  Is this the latest MCU code?
If you do open a case, may require our next level team to look into it.  If you can, let me know your case number here.
Thanks.
VR
Patrick
Dmitry Rudykin
Hello.
Has your problem been solved?
