06-21-2012 02:29 PM - edited 03-17-2019 11:21 PM
I have two C40s registered to Callmanager, MCU 4505 registered to VCS, VCS connected to CallManager over a SIP trunk. I use TMS for scheduling. WHenever I schedule a meeting and connect to the meeting from the C40s, the transmit for both endpoints is negotiated at 768kbps. As far as I can see, I am not limiting it anywhere. If i call from a Movi endpoint registered on VCS to the C40s, I can see it connects at approx 2Mbps also when i call directly between the C40s in CallManager, I also get 2Mbps. Video CAC is set to unlimited on Callmanager and no pipes are setup on VCS but when I call the MCU, the call negotiates at 768Kbps, any ideas what to look for?
Thanks in advance!
06-21-2012 02:34 PM
Look at the default call settings on the c40 endpoints themselves. This may be limiting it. It's under the conference1 setting in the web gui.
Chris
06-21-2012 02:34 PM
Hi George
What is the default bandwidth set to be used when scheduling from TMS? Check it in admin tools --> configuration --> conference settings. Is the bw set to use 768 by default here? It´s only happening when scheduling from TMS right?
Also its worth checking the endpoint it self (C40) what the default bw its set to use.
/Magnus
06-21-2012 02:37 PM
Hi Magnus/Chris,
The default C40 settings are set at 4096Kbps so is TMS.
Magnus,
Yes it happens for scheduled calls. I do not use the Outlook form, just add the endpoints in the attendee list.
06-21-2012 02:45 PM
are you running only sip protocol? I assume you are only running sip with callmanager registration.
The endpoints may be trying to connect to the conference via H323 protocol and getting it's settings there. Any interworking going on?
Disable the h323 protocol on the the endpoints, or maybe try to change the default call protocol to sip instead of h323.
One question, why register to callmanager when you have a vcs? H323 is a more robust protocol right now and will give you more features currently. I think, anyone else chime in here about that.
Just a few things to look at.
Chris
06-21-2012 03:02 PM
I did disable H323 as a test and its does the same thing; negotiates down to 768Kbps.
06-21-2012 03:07 PM
I'm going to go out on a limb here and suggest that there is a hidden setting somewhere in the callmanager you might be missing. Since I have almost no experience with CUCM, I can't really help you out there. Of course I could be full of it. Good Luck
Chris
06-21-2012 05:42 PM
Thanks for trying Chris.
06-21-2012 08:56 PM
Have you check “Max Video Call Bit Rate” setting in the Region on CUCM?
By default this will be 384, multiplied by 2 accounting for both directions.
06-22-2012 06:25 AM
On top of what Tomo is asking you to check here, if placing a call from C40 on CUCM and IWF is picking this up, it may be that since the empty invite from CUCM has no BW specified, VCS sets the BW in Call Setup (h323) towards MCU by using the default Call Bandwidth on the VCS. This looks like it happens when IWF Function is picking this up and my assumption that the call is landing on the MCU as H323.
Verify VCS Configuration>Bandwidth>Configuration for us and see if this is set to 768k? Change setting to 2MEG and remake the call? Does this behavior change?
Let us know?
Thanks in advance.
VR
Patrick
06-22-2012 02:19 PM
The VCS normalization script in CUCM was doing it, now off to figuring out what caused, thanks for your help guys.
