Mic 60 for codec plus
salem
If change mic 60 connector to aux (4 pin), will work with codec plus?
The old Cisco Table Microphone 60 (CTS-MIC-TABL60) has different voltage specs (12V/48V) to what is required on the newer codecs (9V/52V).  You'd be best to swap out the old mic for one of the newer ones made to use the correct and compatible voltage.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
