mic sound to HDMI out on C 60
Emre Ozkan
Beginner
Beginner
Hello all,
How can i give the mic sound to HDMI out on the C 60 at my side and to the other side which is called?
Thank you.
mubakhta
Enthusiast
Enthusiast
Hi Emre,
Have you tried to use Cisco TC Console application ? I would recommend you use that and it would really make it easy for you to make such changes, here's the link of the TC console which you can download and install on your PC:
http://developer.cisco.com/web/telepresence-developer/tools/integrators/tc-console
Hope this helps.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
mubakhta
Enthusiast
Enthusiast
Hi Emre,
Hope this helps.
Mubashshir Akhtar
Hi Emre,
Any specific reason to play local audio on local monitior ? I suspect it will create ECHO in call.
Kind regards,
Dharmmesh
I got the mic sound with TC Console that is make it east, thank you for your help.
Hi Emre,
Glad to see that it helped you. Please mark the question as answered since you're issue is resolved.
Mubashshir Akhtar
Recognize Your Peers
