Missing Back-End on C-60 codec
Anthony Chan
this is what I am geting
is there anything i can do
20 Replies 20
Do you mean you cannot login as admin?
Do you have an SR open for this issue?
a)can you login as admin when using serial cable?  If you can, you can do a factory default by sending the factory reset command
b)are you accessing the web via http or https
c) which TC software are you running
I am not able to login as admin using serial cable but can under as root
able to access thru web portal http but gives me the "Missing Back-end" message
codec was running 3.1.4
have SR # open with TAC and they informed me they are sending me a replacement codec
think this one is totally hooped
I am interested to take a look at this codec, can you send me an email if you wish to.  Then we can probably do a web-ex?
Forgot to update, received new unit from Cisco and now everything is working
was not able to trouble shoot the cause so no resolution was found on that device
thx for the info!
