01-15-2013 06:09 AM - edited 03-18-2019 12:26 AM
scenario:
Jabber Video (external) -> VCS-E -> VCS-C (Active Directory Service) -> TMSPE (user imported from LDAP)
user1@testdomain.com calls user2@testdomain.com both provisioned with TMSPE and online with Jabber Video.
See here a call leg from VCS-E:
Search (349)
State: Completed
Found: False
Reason: Proxy Authentication Required
Type: SIP (INVITE)
CallSerial Number: 39d4d3f6-5f1b-11e2-9206-0010f3249cce
Tag: 39d4d590-5f1b-11e2-99ec-0010f3249cce
Source (1)
Authenticated: False
Aliases (1)
Alias (1)
Type: Url
Origin: Unknown
Value: user1.movi@testdomain.com
Zone (1)
Type: Local
Path (1)
Hop (1)
Address: 192.168.5.10:56075
Destination (1)
Alias (1)
Type: Url
Origin: Unknown
Value: sip:user2@testdomain.com
StartTime: 2013-01-15 14:55:31
Duration: 0.07
SubSearch (1)
Type: Transforms
Action: Not Transformed
ResultAlias (1)
Type: Url
Origin: Unknown
Value: user2@testdomain.com
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: FindMe
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: Search Rules
SearchRule (1)
Name: Traversal zone search rule
Zone (1)
Type: TraversalServer
Protocol: SIP
Found: False
Duration: 0.02
Gatekeeper (1)
Address: 10.10.40.18:25006
Alias (1)
Type: Url
Origin: Unknown
Zone (2)
Protocol: H323
Found: False
Reason: Not registered - Destination not found
Duration: 0.04
Gatekeeper (1)
Address: 10.10.40.18:1719
Alias (1)
Type: Url
Origin: Unknown
and here VCS-C:
Search (76)
State: Completed
Found: False
Reason: Not found
Info: Policy Response
Type: SIP (INVITE)
CallSerial Number: 5f2adfdc-5f1c-11e2-8afc-0010f3249b3a
Tag: 5f276780-5f1c-11e2-ac63-0010f3249cce
Source (1)
Authenticated: True
Aliases (1)
Alias (1)
Type: Url
Origin: Unknown
Zone (1)
Type: TraversalClient
Path (1)
Hop (1)
Address: 194.123.45.67:7001
Hop (2)
Destination (1)
Alias (1)
Type: Url
Origin: Unknown
StartTime: 2013-01-15 15:03:43
Duration: 0.12
SubSearch (1)
Type: Transforms
Action: Transformed
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: FindMe
Action: Proxy
ResultAlias (1)
Type: H323Id
Origin: Unknown
Value: user2.movi@testdomain.com
SubSearch (1)
Type: Transforms
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: FindMe
Action: Proxy
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: Search Rules
SearchRule (1)
Zone (1)
Protocol: SIP
Found: False
Reason: Not found
Duration: 0.07
Gatekeeper (1)
Alias (1)
Type: H323Id
Origin: Unknown
Zone (2)
Protocol: H323
Found: False
Duration: 0.01
Gatekeeper (1)
Address: 194.123.45.67:6001
Alias (1)
Type: H323Id
Origin: Unknown
I have the feeling there is a loop because at the end on vcs-c it goes to the traversal zone?
Any help?
Jason
Solved! Go to Solution.
01-18-2013 11:34 PM
Normale you dont Need add the sip domain on Vcse . And what is the sip proxy settings on the Vcse? It must " proxy to known or all" . Do check this settings. All zones on the Vcse must be on" do not check credentials". And a search rule like any to VCS-c
01-20-2013 02:12 PM
If you intend to have the call from the VCS-E in the VCS-C and then back to the VCS-E you might
need to disable the loop detection of both VCS.
You find that under: VCS configuration > Calls
But this might have some site effects, so you should have full control over your search rules.
Maybe you should ask your Cisco Partner or an external consultant to help you.
If you have a standard mapping of your movi users you could also add a search rule
replicating what the findme account is doing on the VCS-C so the call is directly matched
on the VCS-E or use findme or a CPL/Policy server to handle the calls.
01-15-2013 07:33 AM
If you could tell us a bit more about your deployment.
Like where are your sip domains added (vcs-c or also vcs-e)
How is your setup of the findme uri, device uri.
Where is the device provisioning and findme installed.
How would you expect the call flow to take place?
How do your search rules and transforms look like?
How do your authentication settings look like? (its a bit strange to see the proxy auth error on the VCS-E but nothing in the sip part of the VCS-C log)
If the sip domain is only added on the VCS-C and you do a proxy registration.
Do you see the movi registration on the VCS Registration by Device list?
How do your search rules look like on the VCS-C targeting the local zone?
What do you allow as the "source" for the search rule targeting the local zone?
If its local zone, could you try with "any" or "AllZones"
Did you follow the deployment guide?
01-17-2013 03:13 AM
The SIP domains are configured on the VCS-C and VCE-E. Both the same domain.
The setup of findeme uri and device uri is configured on the TMSPE server.
I have installed a TMS (14.1.1) server with TMSPE and TMSXE. I have a findme device template which is configured with device address pattern -> {username}.jabbervideo@testdomain.com
For the User i have a video address pattern -> {first_name}.{last_name}@testdomain.com
and a device adress pattern -> {username}.{device.model}@testdomain.com
If i log in from external i can see an active device under TMS - Systems -Provisioning - Devices with video address -> user1.movi@testdomain.com
In my opinion, i log in from outside dial another movi user with user2@testdomain.com and the call should go from Internet -> VCS-E -> VCS-C -> lookup in TMS -> VCS-C/E ? (Depending on where the user is logged in with Jabber Video (internal/external) )
i have some transforms and search rules configured on VCS-C. But i think no for movi to movi. Should there some configured?
on VCS-C i have set Default Zone, Traversal Zone, Default Subzone to "check credentials"
I have configured a Subzone "Local VCSC Zone" with treat as authenticated.
on VCS-E i have set Default Zone,TraversalZone, Default Subzone to "do not check crredentials"
sip domain is added to both
yes, on VCS-E i see "user1.movi@testdomain.com"
I have only one search rule von VCS-C configured targeting the local zone and this is from CUCM to VCSC (FROM CUCM to VCSC Registered Devices)
Protocol: Any
Source: Any
Request must be authenticated: no
mode: alias pattern match
pattern type: Regex
pattern string: (.*)@
Pattern behavior: replace
Replace string: \1@testdomain.com
On successful match: stop
Target: LocalZone
Any
i tried this. Nu success.
Yes i did.
01-17-2013 04:13 AM
Hi Born,
is this issure simillar to this thread posted by you.?
https://supportforums.cisco.com/message/3830069#3830069
if the movi/jabber client registration is on VCS-exp under default subzone or specific subzone can you make it as "treat as authenticated" and try again.
Alok
01-17-2013 05:07 AM
Yes its the same. Sorry i noticed to late that i posted it double. :-/
So, i have now some oter input. I tried to call from an external registered movi client to an internal registered movi client. On VCS-E under device registration i see the external movi client and on VCS-C i see the internal movi client registered.
Here are now the call legs if i try to dial from external to internal movi client.
VCS-Express
2x SIP searches from 1 dialing
Search (253)
State: Completed
Found: False
Reason: Not found
Type: SIP (INVITE)
CallSerial Number: 2ecfb8ba-60a4-11e2-ba28-0010f3249cce
Tag: 2ecfba5e-60a4-11e2-8f49-0010f3249cce
Source (1)
Authenticated: True
Aliases (1)
Alias (1)
Type: Url
Origin: Unknown
Zone (1)
Type: Local
Path (1)
Hop (1)
Address: 192.168.5.10:50449
Destination (1)
Alias (1)
Type: Url
Origin: Unknown
Value: sip:user2.movi@testdomain.com
StartTime: 2013-01-17 13:48:25
Duration: 0.2
SubSearch (1)
Type: Transforms
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: FindMe
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: Search Rules
SearchRule (1)
Zone (1)
Protocol: SIP
Found: False
Reason: Not found
Duration: 0.15
Gatekeeper (1)
Address: 10.10.40.18:25007
Alias (1)
Type: Url
Origin: Unknown
Zone (2)
Protocol: H323
Found: False
Duration: 0.04
Gatekeeper (1)
Alias (1)
Type: Url
Origin: Unknown
Search (254)
State: Completed
Found: False
Reason: Not found
Type: SIP (INVITE)
CallSerial Number: 2edadcc2-60a4-11e2-84b4-0010f3249cce
Source (1)
Authenticated: True
Aliases (1)
Alias (1)
Type: Url
Origin: Unknown
Value: user1@testdomain.com
Zone (1)
Path (1)
Hop (1)
Address: 10.10.40.18:5061
Hop (2)
Hop (3)
Destination (1)
Alias (1)
Type: Url
Origin: Unknown
Duration: 0
SubSearch (1)
Type: Transforms
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: FindMe
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: Search Rules
VCS-Control
1x SIP searches from 1 dialing
Search (154)
State: Completed
Found: False
Reason: Not found
Type: SIP (INVITE)
CallSerial Number: 2ed3bc3a-60a4-11e2-ba84-0010f3249b3a
Source (1)
Authenticated: True
Aliases (1)
Alias (1)
Type: Url
Origin: Unknown
Zone (1)
Path (1)
Hop (1)
Hop (2)
Destination (1)
Alias (1)
Type: Url
Origin: Unknown
Duration: 0.11
SubSearch (1)
Type: Transforms
Action: Transformed
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: FindMe
Action: Proxy
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: Transforms
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: FindMe
Action: Proxy
ResultAlias (1)
Type: H323Id
Origin: Unknown
SubSearch (1)
Type: Search Rules
SearchRule (1)
Zone (1)
Protocol: SIP
Found: False
Reason: Not found
Duration: 0.06
Gatekeeper (1)
Alias (1)
Type: H323Id
Origin: Unknown
Zone (2)
Protocol: H323
Found: False
Duration: 0.02
Gatekeeper (1)
Alias (1)
Type: H323Id
Origin: Unknown
01-17-2013 05:30 AM
I have tried it now also from external to external movi.
Bot the same in the search history -> "Not Found"
The Proxy Auth issue has gone. Don`know exactly why...
Any suggestion what i have missing to configure ?
01-17-2013 07:45 AM
Hi Born,
407 proxy authentication required coming because your default subzone was in "do not check credentials".
anyways the search is getting complete now but i want to ask what exactly your are dialing ?? user2.moviz@domain or user2@domain?
because i think your requirement is to dial user2@domain isn't it?
if yes, then why the vcs-exp search is showing destination as user2.movi@domain
Destination (1)
Alias (1)
Type: Url
Origin: Unknown
you should dial user2@domain and if findme is configured correctly it will automatically be taken care.
regds
Alok
01-17-2013 08:28 AM
This is what i thougt too. You are right if you say i have to dial user2@testdomain.com. I think the user2.movi@testdomain.com comes from TMS - Provisioning - User -> Device Address Pattern ?
Should i change this to the same like Video Address Pattern?
But as you see there are two searches if i try to dial this user? One with .movi and one without.
01-18-2013 04:01 AM
Hi Alok, any idea?
01-20-2013 02:12 PM
01-18-2013 11:34 PM
01-24-2013 04:39 AM
Sorry for late respone. I wass offline the last days. I will try this after next week as i`m goging for Cisco Live.
I will give you feedback as soon as possible.
03-06-2013 01:48 PM
Just to close this.
There was missing a search rule for local zone on vcs-c and also on vcs-e if a external movi is connected. Thanks for your help.
