MRA + Conference Now
Andrey Yagunov
when we call to conference now without expressway all works fine. When we call through MRA dtmf doesn't work, we can't enter conference number.
Pls, any advise.
5 Replies 5
Jaime Valencia
Versions? Device?
Have you tested with any other IVR?
java
if this helps, please rate
Expressway 12.5. CUCM 11.5, Jabber 12.8
When I call through MRA to UCCX IVR dtmf works. If I enable mtp at CUCM phone settings, it also work.
P.s. I don't have sip trunk to expressway c.
What is the exact call flow?
java
Cisco Jabber - Expressway e - Expressway c - CUCM - Conference now
I suggest you open a TAC case to have this looked at, most of the similar issues I've seen involved a SIP trunk/CUBE in the call flow or older versions of expressway that had issues with DTMFs.
java
