MRA configuration- Jabber from internet
Dear Experts;
I am facing an issue while creating traversal zone in my VCS-E and VCS-C;
trying to configure remote expressway; Please find the attachment for the configuration. could you guys please support me to understand it better.
Please find the overview of the configuration which i have done;
  1. Set Unified Communication mode to Mobile Remote Access in both VCS –C and VCS E
  2. Configure Unified CM and IM&P on the Expressway- C;
  3. Configured the domains on Expressway-C for which services are to be routed to UCM
  4. Installation of suitable security certificate on the Expressway-C and the Expressway-E
  5. Since I am not using TLS verified mode is set to ON,  so didnt uploaded the CUCM and IM&P tomcat certificates.
  6. uploaded the singed certificate to both VCS-C and E;
  7. configured the traverzone;
    1. type : Unified Communications Traversal
    2. port : 7020 (7001 used for  another traversal zone with type: traversal server; which is working fine)
    3. h323 set to be off
  8. when I save the configuration in both VCS-E and VCS-C the status is showing faile with reason code system not reachable.
  9. using peer address as host name which i can ping from server to server.
  10. so kindly  support me to configure it proper if i miss something.
Shalid
7 Replies 7
Addition to above , i am getting port conflict error in VCS-C
There is a port conflict on Unified CM 10.XX.XX.XX between neighbor zone CUCM Neighbor and Unified Communications (both are using port 5060);
i have another zone neighbor zone which use the same port 5060 for B2B video calls. Do I need to change the port number in VCS and SIP trunk in cucm?
Finally my MRA configuration works well..
Please find below steps which i had taken to complete the configuration.
  1. Jabber Client must verify the identity of the Expressway-E they are connecting to by validating its server certificate. To do this, the client must have the certificate authority that was used to sing the Expressway-E’s server certificate in their list of trusted CA’s
  2. DNS records,
    1. The public DNS must be configured with  _collab-edge._tls<domain> SRV records. (_collab-edge._tls.sample.com )
      1. Domain
        Service
        Protocol
        Priority
        Weight
        Port
        Target host
        sample.com
        collab-edge
        Tls
        tp-vcse.sample.com
        sample.com
        sips
        Tcp
        tp-vcse.sample.com
  • Local DNS requires _cisco-uds._tcp.<domain>  and _cuplogin._tcp.<domain> SRV records.
  • _cisco-uds._tcp.sample.com
  • _cuplogin._tcp.sample.com
  • Domain
    Service
    Protocol
    Priority
    Weight
    Port
    Target host
    sample.com
    cisco-uds
    tcp
    10.200.1XX.XX
    sample.com
    cuplogin
    tcp
    10.200.1XX.XX
 Validation from System Team
3. The Phone Security Profiles in UCM that are configured for TLS and are used for devices requiring remote access must have a name in the form of an FQDN that includes the enterprise domain. (this is because those names must be present in the list of Subject Alternate Names in the Expressway –C’s server certificate.
  • Configured security profile jabber.sample.com  by modifying  Cisco Unified Client Services Framework - Standard SIP Non-Secure Profile
  1. Ensured that AXL services are activated in Publisher and IM&P
  2. Ensured that NTP are configured and synchronized properly
Expressway:
  1. System                 host name and Domain name are specified for every Expressway and all Expressways are synchronized with NTP
Expressway –C
Express E
           In expressway- E, TURN services are set OFF.
  • Configured but mention TLS as off
  • Configured the domains on Expressway-C for which services are to be routed to UCM
Since I am not using TLS verified mode is set to OFF ,  so not uploading the CUCM and IM&P tomcat certificates.
Configuring traversal Zone in Expressway
Configured traversal  zone for Cisco unified communication type in VCS-E and VCS-C as below;
Issue Faced during configuration:
  1. The traversal zone was not coming active.
    1. Open the port 7001 – 7005 from firewall between VCS-C and VCS-E
    2. Open port 7400 from VCS-E
    3. We must use 5060  and 7001 for MRA, so re-configured the CUCM neighbor zone with 5063
i.In cisco call manager change the listening port from the SIP security profile used for VCS trunk from cisco call manager.
ii.SystemSecuritySIP Trunk Security Profile
Change the corresponding value in VCS-C
Any changes in the configuration of network related information may  either required a system restart or re-configure the related configuration such as traversal zone …(I had face this issue and solved by this method only.)
Phone Configuration in CUCM:
Android / Iphone:
from the end user page subscribe the user service profile
Home Cluster : should be checked
Enable User for Unified CM IM and Presence : should be enabled.
Device should be associated with user.
Configure phone as below:
  1. Device type : Cisco Dual Mode for Android /Cisco Dual Mode for iPhone
  2. Device Name :  Should be start with BOT for android and TCT for IPhones
  3. Owner :  Assign respective user account
  4. SIP Profile : Standard SIP Profile for Mobile Device
  5. Device Security Profile : Cisco Dual Mode for Android.
  6. Save the Configuration.
  7. Configure Line for the user.
Login from Jabber:
  1. From advance Option on Jabber login Page select IM
  2. Fill user name and password
  3. Enter the VCS-E FQDN (tp-vcse.sample.com)
No you Ready to make first VoIP call from internet using jabber.
  1.
Clifford McGlamry
So, what did you have to change to get rid of the System Unreachable?
I see the steps for your full config below, but I'm trying to figure out why, if I follow the documentation I get System Unreachable.
I have not put certificates on the devices as I was going to go with the self signed certs for now.
How did you resolve that issue?
I guess that you are facing system unreachable iin traversal zone,
1. check about the ports are opened between VCS-E and VCS-C ; Please refer page# 22 in  http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-1/Mobile-Remote-Access-via-VCS-Deployment-Guide-X8-1-1.pdf
2. check the credential configured in VCS-E and VCS-C traversal zone.
if everything is correct, Please recreate the same ; it will work. I had faced same issue initially the problem with port and even after everything was correctly configured i was facing the issue. then Cisco TAC advised me to re-create it again and it works well.
Let me know if you still face the issue; you can also check the dumplogs Maintenance -->Diagnostics-->Diagnostic Logging and share the logs.
Shalid.
Logs showed an authentication error.  Turns out that you CANNOT use the self signed certs for communication between the E and C boxes.
Customer is working on getting "real" certs.
Not really required. You can get it signed from internal system team from their CA. This is what I have done. Generated request from each vcs server and get it signed from internal A AND uploaded to respective vcs servers.
Also did you recreated the zone?
Please keep update .
Yes, the zone was recreated.  But the certs on the boxes were the self signed ones from installation.  There is no avoiding having a CA (even a private one) involved.
