09-27-2013 05:32 AM - edited 03-18-2019 01:52 AM
Good morning. I am having a hard time trying to figure out what OS the MSE 8000 series is running. If anyone can help it would be greatly appreciated. Thank you.
09-29-2013 04:24 PM
Are you referring to the software version or build number? If so, here it is.
Login to MSE then go to Status. Under System Status you'll see the software version, build and other relevant information.
Please rate replies and mark question as "answered" if applicable.
09-29-2013 05:41 PM
Hi Donald,
The MSE 8000 series is a Chasis that can contain blades (10 from memory). Usually it contains a Sup blade and MCU blades etc.
These baldes have individual IP address and can be accessed via Web and they have their own individual versions.
Hope this helps.
09-30-2013 02:13 AM
Hi Donald
Cisco/TANDBERG/Codian MCU and others based on a custom build of Free & Open BSD OS with some Linux and PicoOS in there as well for certain functions.
You can find all about what's in there if you login to your blades and hit the Help link and right at the bottom of that you'll see a Further Information>Contact details & Licence Information section it's all in there.
c/
