04-02-2012 04:46 AM - edited 03-17-2019 10:59 PM
Hi Telepresence Experts,
I went through the MSE 8000 deployment guides, and I can only see the MSE 8000 power requirements and other requirements.
But I cannot see anywhere the Rack Specification for installing MSE 8000.
I need to provide the RACK specification to my Customer so that they can build the rack accordingly.
Or is it something, which Customer can also order to Cisco? If yes, Can you pass the PID?
Saurabh
Solved! Go to Solution.
04-02-2012 05:01 AM
Hi Saurabh - Good morning. Under physical dimensions:
http://www.tandberg.com/collateral/product_brochures/TANDBERG_Codian_MSE_8000.pdf
PHYSICAL DIMENSIONS
Height 33.25", 842 mm (19U)
Width 17.2", 437 mm
Depth 20.5", 520 mm
19" rack mountable (kit supplied)
Power -48 VDC, 100–240 VAC 50/60 Hz
Power shelves are Valere Power Shelves are 1U for each shelf. Does this help?
VR
Patrick
04-02-2012 05:01 AM
PHYSICAL DIMENSIONS
Width 17.2", 437 mm
Depth 20.5", 520 mm
VR
Patrick
04-02-2012 10:13 PM
Hey Patrick,
Thanks for the reply. I hope you remember me as well, I was in TAC before , went on video call with you once for our lab MCU issue.
Coming over to this , so I can pass this physical specs and dimensions to the customer and he will ask his infrastructure team to create MCU Rack, is it also orderable from Cisco?
Thanks Again!
Saurabh
04-03-2012 04:49 AM
HI Saurabh. Thought that was you. Glad to see your doing well!
Any MCU going into the chassis system will simply slide in to the system, This physical dimensions is for the entire chassis itself. Any blade purchased by the customer will just slide into one of the slots on the chassis system itself.
As far as ordering the actual physical rack itself, I'm not sure, but i'm pretty sure we may supply racks to house the system in, I'm just not sure how to order that.
VR
Patrick
