Multiparty Call from VC
wajid_dabir
Hi Team,
We have Cisco sx20 & C60 model standalone VC system and would like to know whether these VC's have multi party license or not.
How can I check from VC? does it comes by default with VC?
Please help.
Patrick Sparkman
I presume you're asking about the Multisite option key, the embedded MCU feature on the endpoint, and is a paid option key.
You can check the system information page if you log into the web interface of the endpoint to see if the option key is present, or you can also check using SSH.
xStatus SystemUnit Software OptionKeys MultiSite
Both the SX20 and C60 can support up to 4 participants when using Multisite, 3 external endpoints + the host endpoint.
In addition to what [@patrick.sparkman]  (+5) has written in his response, If the endpoints don't have the Multisite Option Key installed, you can check to see if one is available on the www.cisco.com/go/licence portal by requesting a resend of the licences for your device's serial number.
If you don't have one available at all on the C60, you're out of luck as the C60 is an End of Sale device.  You can still purchase one for the SX20 though as they are a current model.
Note: Your question would be better placed in the TelePresence section of the forums where these devices are more actively discussed than in the Conferencing section you've posted in - I'd suggest, if the above hasn't answered your query, that you move your discussion over there (you can do this by editing your original post and changing the category at the bottom).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
