Multisite option for sx20
salem
Is the LIC-SX20-MS unique for a S/N ?
Or we can buy it , later decide it activate on one of our SX20 ?
When we buy this license  we must input it directly to SX20
or must register it in cisco site for preparing option key ?
Wayne DeNardi
If you purchase it now, you will receive a licence PAK.  This isn't tied to any specific device at that point, but cannot be used until it is registered.
When you decide you want to install it, you will need to generate an option key on the licencing portal which needs to be assigned to a specific SX20 serial number.  The licence is then tied to that one device and cannot be used on another device.
The process is described in the Option Keys scenario section of the Activation Key Process Self Service Guide.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
You can buy Multisite license for SX20 and receive PAK number for activation.
After recieved PAK you go to the www.cisco.com/go/license and need enter your PAK and S/N your SX20. You recive function key and this key need add to your SX20.
Wayne DeNardi
Wayne
Thanks Wayne.
salem
