MX200 Question
Tim
                   A customer has an MX200 and is able to connect and make calls to test number sites, the endpoint can call me on my personal jabber account but cannot connect to any endpoints through our expressway, not even auto attendant and I am not able to call into their endpoint. They used the firewall port config from cisco, does anyone have any ideas  of  what to check? Thanks.
Do you get any errors on the vcs e under search history?
Best Regards
Yes, it is not always the same error but I get no route to destination as one of the messages or temporary busy is another.
can you maybe give me a screenshot of your search rules and your transforms.
Best Regards
