MX300 G2 Built-in Microphone
philokoi0
The MX300 G2 has a  Built-in Microphone, I have 2 questions:
- Where is this microphone located?
- Is there a way to disable it, we use this system in a room with audio from the room (Micros/Loudspeakers) and this micro is disturbing our meeting.
Thanks in advance,
Philippe
Hi Philippe
You may see inbuilt microphone in bezel under the camera. See administrator guide for MX300( page-7).  http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/mx-series/tc7/administration-guide/mx300g2-administrator-guide-tc70.pdf
I don’t have MX300G2 in my lab, but I think  steps for MIC same as for other TC-endponts.
Can you try next:   Configuration>Audio>Microphone (1-2-3) > Mode (On/Off)   ? (page-52)
br Oleksandr
Hi Philippe
br Oleksandr
Thank you Oleksandr.
gabi.albert
hello Philippe,
did you get to solving this issue? We have the same issue?
thanks and regards,
Gabriel
Yes as Oleksandr said, using the command line: xconfig audio input microphone 1 mode: off
Philippe
