MX300 g2
Daweeks318
Beginner
Beginner
Has anyone set up a MX300 g2 video unit with dual screens? The second screen we want to use is a samsung flat screen tv?  Our organization has a dual screen video unit, but in TMS it is registered as a "Profile 52/55 Dual".  Am I going to need another license or is it as simple as connecting a HDMI cable from the video unit to the tv? The second screen will only be for sharing presentations.
It is as simple as plugging in an HDMI cable to the video out.  The MX300 G2 should start using the second display when you try to send presentation content, but you might have to change the following settings in the MX300 G2 yourself if it doesn't.
Congiuration Video Monitors: DualPresentationOnly
As for TMS, it doesn't matter in this regard, but what version of TMS are you using?
Recognize Your Peers
