MXP Multiway vs. Multiside
JensLantermann
Beginner
Beginner
Hi everyone,
we had migrated some new (old) Videoendpoints.
Actually we have trouble with an 6000MXP (F9.0.2  PAL). The problem is we have an multisidfe option installed and so the Endpoint
is not using the MCU. How can we convince these endpoint to use the MCU?
Tnaks a lot!
Tomonori Taniguchi
MXP with recent software must select either Multisite (use embedded MCU feature) or Multiway (conference escalation using external MCU bridge).
As videoconftech mention, you need to configure which conference method to be use on Endpoint (can’t activate both on same time).
6 Replies 6
Jens Didriksen
Engager
Engager
Through web GUI: Endpoint Configuration-->General-->Multi Point Call Options-->Multi Point
choices are Off, Multisite or Multiway - select Multisite.
Through CLI:
xConfiguration Multipoint Mode:
set to
xConfiguration Multipoint Mode: Multisite
Also remember to set "Allow Incoming Calls when in Call" permission to "On" if you want to allow other sites to dial in for mutisite conferences.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
we use tms SmartScheduler.
We have configured Multiway at the Endpoint, tms sees multiside optionkeys and won't use the MCU when Number of Partner is less than 5.
Is there a Way to prefer multiway all all the time.
kind regards
Martin
When you say "we use TMS smart scheduler", do you mean to say that these are scheduled conferences where you wish to use the MCU?
If so, in TMS go to:
Administrative Tools > Conference Settings > Advanced > External MCU Usage in Routing: > "Always, except point-to-point"
Thanks you solved my problem!
kind regards
Martin
Glad to hear it Martin - please rate and/or mark useful posts as "Correct" for others searching the forum with the same problem :)
Tomonori Taniguchi
