NAT & H323
scolombo
I've a video conferencing application on some hosts inside my network which need to connect to a H323 Gatekeeper outside ( internet )
The internet connection is made via a 1401 router with IOS 12.2.6 .
We tested the configuration with a static nat for one of the internal host.
The connection goes through but at the endpoint our host present itself with its internal IP .
How can we solve the translation problem ?
56 Replies 56
hi alan,
can you send me a copy of the doc too?
thanks,
roy (roy@cybees.com)
can I also got a copy
slam@ttasia.com
May I have a copy of these docuemnts?
Troy.High@tetoninterlink.com
Troy
A copy of this document would be greatly appreciated.
Hi Alan,
Could you forward me a copy of that document as well. Thanks.
anthony_lee@walla.com
Anthony.
hi Alan,
Could you email me a copy of the said document as well?
Thanks in advance
chris
H Alan,
will you send me that document that explan the NAT and H323 to my e-mail account:
cvitan@advnetworking.com
Thank you
Crstian
please send me copy too
zorin@super-computer.ru
I would also like a copy.
Would you e-mail me a copy.
Laurent
laurent.pillet@edu.ge.ch
anorman
You have two options here, The first being an ALG (Aplication Level Gateway) for H.323/Video. This might be a PIX type device which will read into and re-write the ip address info of all the signalling and media information being sent out from the internal (private) endpoint. You also may wish to use an H.323 proxy with internal and external interfaces to broker the signaling and media with the outside world. Your best bet is option number two from a cost standpoint. I believe Cisco makes a Proxy.
I need these docs too. Please send it to michael.gergov@gcs-net.net
donuama
please i need a copy too,i appreciate your kindness.
gcost
Thanks in advance for the doc also.
Pls email me too. ta.
I retract the thanks, as nothing developed from this post.....
