New Webex Room Bar - Cable Management
dmheiskell
We have several Webex standard room kits in our enterprise, but moving forward will be deploying the newer Webex Room Bar Pro(s).  With the room kits, we were able to order an optional cable cover/mount for cable management, but it doesn't appear that there is an option for the Room Bar(s).  Is this something that is coming in the near future?  The Room Kit mounts do not appear to be compatible.  Please advise.  Thanks!
Jonathan Schulenberg
You can invert the Room Bar so the cable connections are on top, hidden behind the display when mounted below it. The fabric cover also flips around so the Cisco logo orientation is correct. Check the install guide.
natalie.bennett
Hi dmheiskell, the room bars can be mounted either on the wall or attached to the screen.  The bar itself has a rounded edge which fills in the gap between the bar and screen.  The bar can be inverted (the cover comes off so you can make the Cisco logo the right way up).  Very happy with this model.  We also have Room Kit Minis and Room Kits and the Bar (or Bar Pro) is an improvement on both.
