02-25-2015 08:28 AM - edited 03-18-2019 04:05 AM
Our deployment scenario is End point >>>CUCM>>Expressway-C>>>Expressway-E and NATting at external firewall pointing to VCS-E. When I dial external call, call is connected but showing no incoming video message.
I uploaded diagnosis log fie for your review.
Appreciate any advise and suggest me which place should I check?
02-26-2015 02:21 AM
Hi yeminwin123,
I'm not 100% sure, but I didn't think that the Expresway-E should be NAT'ed on it's external interface.
Chris
03-08-2015 10:54 PM
There are multiple threads here talking about how NAT has to be used with the VCS-E, which behaves similar here as the Expressway-E-
Its a valid deployment but requires the external NAT ip to be set.
In addition either the second interface has to be used or also the internal communication from the -C to the -E has to flow to the external NAT ip.
see also
http://www.cisco.com/c/en/us/support/docs/unified-communications/expressway-series/117811-configure-vcs-00.html
03-08-2015 11:15 PM
We managed to solved by enabling dual network card options. So that we don't need to point to NATted IP of exp E. NAT reflection must be supported on router v or firewall to point to natted IP.
