NTP status
mohammadfayek19
connection to NTP server not yet established. this might be that we have not yet had the time to establish connection or NTP server is unavailable.
Many reasons
Ntp server not reachable
Ntp server have acl prevent connect
...etc.
Try first debug ntp packet and see
Not clear on what your question is, it looks like your "just" posting the output from a system. The output as such is IMHO pretty straightforward, it basically says that the device cannot reach the NTP system. Have you verified that it has connectivity to the set NTP system?
Response Signature
M02@rt37
Hello @mohammadfayek19
Could you please more elaborate ?
Best regards
PJMack
Level 7
Level 7
What NTP server are you trying to use? Is it on your network or public? If public are you sure you are allowing the traffic on your firewall(s)?
